Helaas is de update catalog van microsoft op het moment niet beschikbaar. Wel heb ik de tool gebruikt en daar kwam dit uit:
Ran by Fabian (administrator) on 07-01-2018 at 14:07:31
Running from "C:\Users\Fabian\Desktop"
Microsoft Windows 10 Pro (X64)
Model: GE70 2OC\2OD\2OE Manufacturer: Micro-Star International Co., Ltd.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Killer E2200 Gigabit Ethernet Controller = Ethernet (Connected)
TAP-Windows Adapter V9 = Ethernet 2 (Media disconnected)
Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC = Wi-Fi (Media disconnected)
Bluetooth Device (Personal Area Network) = Bluetooth-netwerkverbinding (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global taskoffload=enabled
set interface interface="LAN-verbinding* 12" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth-netwerkverbinding" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 9" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : DESKTOP-MJ7L3V9
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Killer e2200 Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 8C-89-A5-0E-9E-8C
IPv6 Address. . . . . . . . . . . : 2a02:a449:1109:1:682f:2d6e:38c4:6f6e(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:a449:1109:1:a0ba:7306:2545:1aa6(Preferred)
Link-local IPv6 Address . . . . . : fe80::682f:2d6e:38c4:6f6e%6(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.34(Preferred)
Lease Obtained. . . . . . . . . . : zondag 7 januari 2018 12:34:02
Lease Expires . . . . . . . . . . : maandag 8 januari 2018 12:34:02
Default Gateway . . . . . . . . . : fe80::8ad2:74ff:fe82:3341%6
192.168.2.254
DHCP Server . . . . . . . . . . . : 192.168.2.254
DHCPv6 IAID . . . . . . . . . . . : 143428005
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-6F-8F-95-8C-89-A5-0E-9E-8C
DNS Servers . . . . . . . . . . . : 192.168.2.254
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC
Physical Address. . . . . . . . . : 24-0A-64-EA-2A-F0
Wireless LAN adapter LAN-verbinding* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : TAP-Windows Adapter V9
Physical Address. . . . . . . . . : 00-FF-FD-7D-1C-49
Ethernet adapter Bluetooth-netwerkverbinding:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 24-0A-64-EA-4D-7B
Server: mijnmodem.kpn.home
Address: 192.168.2.254
Addresses: 2a00:1450:4007:812::200e
216.58.204.142
Pinging google.com [2a00:1450:4007:812::200e] with 32 bytes of data:
Request timed out.
Request timed out.
Ping statistics for 2a00:1450:4007:812::200e:
Packets: Sent = 2, Received = 0, Lost = 2 (100% loss),
Addresses: 2001:4998:c:e33::53
2001:4998:58:2201::73
2001:4998:44:204::100d
98.138.252.38
98.139.180.180
206.190.39.42
Pinging yahoo.com [2001:4998:44:204::100d] with 32 bytes of data:
Request timed out.
Request timed out.
Ping statistics for 2001:4998:44:204::100d:
Interface List
6...8c 89 a5 0e 9e 8c ......Killer e2200 Gigabit Ethernet Controller
8...24 0a 64 ea 2a f0 ......Realtek RTL8723AE Wireless LAN 802.11n PCI-E NIC
16...24 0a 64 ea 2a f0 ......Microsoft Wi-Fi Direct Virtual Adapter
17...00 ff fd 7d 1c 49 ......TAP-Windows Adapter V9
9...24 0a 64 ea 4d 7b ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.2.254 192.168.2.34 25
192.168.2.0 255.255.255.0 On-link 192.168.2.34 281
192.168.2.34 255.255.255.255 On-link 192.168.2.34 281
192.168.2.255 255.255.255.255 On-link 192.168.2.34 281
224.0.0.0 240.0.0.0 On-link 192.168.2.34 281
255.255.255.255 255.255.255.255 On-link 192.168.2.34 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
6 281 ::/0 fe80::8ad2:74ff:fe82:3341
1 331 ::1/128 On-link
6 281 2a02:a449:1109:1::/64 On-link
6 281 2a02:a449:1109:1:682f:2d6e:38c4:6f6e/128
On-link
6 281 2a02:a449:1109:1:a0ba:7306:2545:1aa6/128
On-link
6 281 fe80::/64 On-link
6 281 fe80::682f:2d6e:38c4:6f6e/128
On-link
1 331 ff00::/8 On-link
6 281 ff00::/8 On-link
Persistent Routes:
None
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [63488] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [334744] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [79872] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [402992] (Microsoft Corporation)
Application errors:
Error: (01/07/2018 12:34:33 PM) (Source: SideBySide) (User: )
Description: Kan activeringscontext voor 'Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0"1' niet maken.
Kan afhankelijke assembly Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0" niet vinden.
Gebruik sxstrace.exe voor een gedetailleerde diagnose.
Error: (01/07/2018 12:29:43 PM) (Source: SideBySide) (User: )
Error: (01/07/2018 12:28:09 PM) (Source: SideBySide) (User: )
Description: Kan activeringscontext voor C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_15cbcf8893620c09.manifest1 niet maken. Fout in manifest of beleidsbestand C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_15cbcf8893620c09.manifest2 op regel C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_15cbcf8893620c09.manifest3.
Een onderdeelversie die nodig is voor de toepassing, conflicteert met een andere onderdeelversie die reeds actief is.
Conflicterende onderdelen zijn:
Onderdeel 1: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_15cbcf8893620c09.manifest.
Onderdeel 2: C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_5d79065fa7de350f.manifest.
Error: (01/07/2018 11:43:28 AM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll8
Error: (01/07/2018 11:43:22 AM) (Source: SideBySide) (User: )
Error: (01/07/2018 11:42:22 AM) (Source: SideBySide) (User: )
Error: (01/06/2018 09:29:04 PM) (Source: SideBySide) (User: )
Error: (01/06/2018 09:29:00 PM) (Source: SideBySide) (User: )
Error: (01/06/2018 09:27:45 PM) (Source: Perflib) (User: )
Description: WmiApRplC:\WINDOWS\system32\wbem\wmiaprpl.dll4
Description: rdyboost4
System errors:
Error: (01/07/2018 02:01:06 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Description: toepassingsspecifiekLokaalActiveren{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}DESKTOP-MJ7L3V9FabianS-1-5-21-825608141-1909588933-4129890093-1001LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (01/07/2018 12:43:08 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Error: (01/07/2018 12:34:38 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Error: (01/07/2018 12:34:30 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Error: (01/07/2018 12:34:04 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalActiveren{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (01/07/2018 12:33:37 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Description: {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5}
Error: (01/07/2018 12:30:02 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Error: (01/07/2018 12:29:50 PM) (Source: DCOM) (User: DESKTOP-MJ7L3V9)
Error: (01/07/2018 12:29:26 PM) (Source: DCOM) (User: NT AUTHORITY)
Microsoft Office Sessions:
Error: (01/07/2018 12:34:33 PM) (Source: SideBySide)(User: )
Description: Avast.VC140.CRT,processorArchitecture="x86",publicKeyToken="fcc99ee6193ebbca",type="win32",version="14.0.23918.0"C:\Program Files (x86)\AVG\Antivirus\defs\18010604\aswEngin.dll
Error: (01/07/2018 12:29:43 PM) (Source: SideBySide)(User: )
Error: (01/07/2018 12:28:09 PM) (Source: SideBySide)(User: )
Description: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_15cbcf8893620c09.manifestC:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.16299.125_none_5d79065fa7de350f.manifestD:\Audacity\audacity.exe
Error: (01/07/2018 11:43:28 AM) (Source: Perflib)(User: )
Error: (01/07/2018 11:43:22 AM) (Source: SideBySide)(User: )
Error: (01/07/2018 11:42:22 AM) (Source: SideBySide)(User: )
Error: (01/06/2018 09:29:04 PM) (Source: SideBySide)(User: )
Error: (01/06/2018 09:29:00 PM) (Source: SideBySide)(User: )
Error: (01/06/2018 09:27:45 PM) (Source: Perflib)(User: )
CodeIntegrity Errors:
Date: 2018-01-07 14:04:33.957
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\System32\dllhost.exe) attempted to load \Device\HarddiskVolume2\Program Files (x86)\Overwolf\0.109.1.40\x64\OWExplorer.dll that did not meet the Microsoft signing level requirements.
Date: 2018-01-07 14:04:33.950
Date: 2018-01-07 14:04:33.941
Date: 2018-01-07 13:59:33.977
Date: 2018-01-07 13:59:33.963
Date: 2018-01-07 13:59:33.949
Date: 2018-01-07 13:54:33.973
Date: 2018-01-07 13:54:33.959
Date: 2018-01-07 13:54:33.945
Date: 2018-01-07 13:49:33.975
µTorrent (HKCU\...\uTorrent) (Version: 3.5.0.43804 - BitTorrent Inc.)
Audacity 2.2.0 (HKLM-x32\...\Audacity_is1) (Version: 2.2.0 - Audacity Team)
AVG (HKLM\...\{BE1A8A5D-8197-48D3-8A41-4360888B7306}) (Version: 1.231.2 - AVG Technologies) Hidden
AVG PC TuneUp (HKLM-x32\...\{82B9AF2D-4254-428A-9D1E-7714BA91A4B0}) (Version: 16.76.2 - AVG Technologies) Hidden
AVG PC TuneUp (HKLM-x32\...\AVG PC TuneUp) (Version: 16.76.3.18604 - AVG Technologies)
AVG Protection (HKLM-x32\...\AVG Antivirus) (Version: 17.3.3011 - AVG Technologies)
BitTorrent (HKCU\...\BitTorrent) (Version: 7.10.0.43917 - BitTorrent Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 5.38 - Piriform)
CyberGhost 6 (HKLM\...\CyberGhost 6_is1) (Version: - CyberGhost S.A.)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
Discord (HKCU\...\Discord) (Version: 0.0.299 - Discord Inc.)
ELAN Touchpad 15.13.8.2_X64_WHQL (HKLM\...\Elantech) (Version: 15.13.8.2 - ELAN Microelectronic Corp.)
FMW 1 (HKLM\...\{36133E9F-B129-4206-9FB4-13F707787542}) (Version: 1.226.3 - AVG Technologies) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 58.0.3029.81 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
Gyazo 3.3.5 (HKLM-x32\...\{6DB8C365-E719-4BA5-9594-10DFC244D3FD}_is1) (Version: - Nota Inc.)
hide.me VPN 1.3.2 (HKLM-x32\...\{0E00BDA5-7998-4889-BE4B-39A4BBD2EDFB}_is1) (Version: 1.3.2 - eVenture Limited)
inSSIDer Home (HKLM-x32\...\{9E54E4AE-B67A-4925-8E92-0E1F9817FD73}) (Version: 3.1.2.1 - MetaGeek, LLC)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 20.19.15.4835 - Intel Corporation)
IntelliJ IDEA Community Edition 2017.2.3 (HKLM-x32\...\IntelliJ IDEA Community Edition 2017.2.3) (Version: 172.3968.16 - JetBrains s.r.o.)
Java 8 Update 151 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180151F0}) (Version: 8.0.1510.12 - Oracle Corporation)
KB4023057 (HKLM\...\{264FDD69-C4DF-476F-B1B8-7DCEE4AF839B}) (Version: 2.4.0.0 - Microsoft Corporation)
London 2012: The Official Video Game of the Olympic Games (HKLM\...\Steam App 71420) (Version: - SEGA Studios Australia)
MEGAsync (HKLM-x32\...\MEGAsync) (Version: - Mega Limited)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.3.7131.1115 - Microsoft Corporation)
Microsoft OneDrive voor Bedrijven 2013 - nl-nl (HKLM\...\GrooveRetail - nl-nl) (Version: 15.0.4989.1000 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable - x86 8.0.61001 (HKLM-x32\...\{710f4c1c-cc18-4c49-8cbf-51240c89a1a2}) (Version: 8.0.61001 - Microsoft Corporation)
Microsoft Visual C++ 2010 Redistributable - x86 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.10.25008 (HKLM-x32\...\{f1e7e313-06df-4c56-96a9-99fdfd149c51}) (Version: 14.10.25008.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 (HKLM-x32\...\{c239cea1-d49e-4e16-8e87-8c055765f7ec}) (Version: 14.10.25008.0 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Minecraft (HKLM-x32\...\{1C16BCA3-EBC1-49F6-8623-8FBFB9CCC872}) (Version: 1.0.3.0 - Mojang)
Mount&Blade Warband (HKLM-x32\...\Mount&Blade Warband) (Version: - )
Movie Maker (HKLM-x32\...\{38F03569-A636-4CF3-BDDE-032C8C251304}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{DD67BE4B-7E62-4215-AFA3-F123A800A389}) (Version: 16.4.3528.0331 - Microsoft Corporation) Hidden
MXGP2 - The Official Motocross Videogame (HKLM\...\Steam App 400800) (Version: - Milestone S.r.l.)
NVIDIA GeForce Experience 3.11.0.73 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.11.0.73 - NVIDIA Corporation)
NVIDIA Grafisch stuurprogramma 388.71 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 388.71 - NVIDIA Corporation)
NVIDIA PhysX Systeem Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
OBS Studio (HKLM-x32\...\OBS Studio) (Version: 19.0.3 - OBS Project)
Office 15 Click-to-Run Extensibility Component (HKLM-x32\...\{90150000-008C-0000-0000-0000000FF1CE}) (Version: 15.0.4989.1000 - Microsoft Corporation) Hidden
Office 15 Click-to-Run Licensing Component (HKLM\...\{90150000-008F-0000-1000-0000000FF1CE}) (Version: 15.0.4989.1000 - Microsoft Corporation) Hidden
Office 15 Click-to-Run Localization Component (HKLM-x32\...\{90150000-008C-0413-0000-0000000FF1CE}) (Version: 15.0.4989.1000 - Microsoft Corporation) Hidden
Overwolf (HKLM-x32\...\Overwolf) (Version: 0.109.1.40 - Overwolf Ltd.)
PLAYERUNKNOWN'S BATTLEGROUNDS (HKLM\...\Steam App 578080) (Version: - Bluehole, Inc.)
Popcorn Time (HKLM-x32\...\Popcorn Time_is1) (Version: 5.6.1.0 - Popcorn Time)
Pro Cycling Manager 2016 Language Changer (HKLM-x32\...\Pro Cycling Manager 2016_is1) (Version: - )
Razer Synapse (HKLM-x32\...\{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.21.00.721 - Razer Inc.)
Skype™ 7.40 (HKLM-x32\...\{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.40.151 - Skype Technologies S.A.)
Speccy (HKLM\...\Speccy) (Version: 1.31 - Piriform)
Spotify (HKCU\...\Spotify) (Version: 1.0.70.388.g8e1ed5af - Spotify AB)
Taalpakket voor Microsoft Visual Studio 2010 Tools for Office Runtime (x64) - NLD (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64) Language Pack - NLD) (Version: 10.0.50903 - Microsoft Corporation)
TAP-Windows 9.21.2 (HKLM\...\TAP-Windows) (Version: 9.21.2 - )
TeamSpeak 3 Client (HKCU\...\TeamSpeak 3 Client) (Version: 3.1.3 - TeamSpeak Systems GmbH)
Total War - Rome II (HKLM-x32\...\Total War - Rome II_R.G. Mechanics_is1) (Version: - R.G. Mechanics, markfiter)
VEGAS Pro 14.0 (64-bit) (HKLM\...\{4C79D80F-79F9-11E6-8402-BB95F5A309BD}) (Version: 14.0.161 - VEGAS)
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2012 x86 Redistributables (HKLM-x32\...\{98EFF19A-30AB-4E4B-B943-F06B1C63EBF8}) (Version: 14.0.0.1 - AVG Technologies CZ, s.r.o.)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
Vulkan Run Time Libraries 1.0.61.0 (HKLM\...\VulkanRT1.0.61.0) (Version: 1.0.61.0 - LunarG, Inc.) Hidden
Windows Movie Maker 2016 (HKLM-x32\...\{3CC29C1A-B5FE-457B-8F22-32A2videowin}}_is1) (Version: - videowinsoft.com)
WinRAR 5.40 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.40.0 - win.rar GmbH)
Percentage of memory in use: 32%
Total physical RAM: 8110.89 MB
Available physical RAM: 5513.66 MB
Total Virtual: 9390.89 MB
Available Virtual: 6191.86 MB
1 Drive c: () (Fixed) (Total:110.53 GB) (Free:9 GB) NTFS
2 Drive d: (Schijf D) (Fixed) (Total:698.63 GB) (Free:410.28 GB) NTFS
Gebruikersaccounts voor \\DESKTOP-MJ7L3V9
Administrator DefaultAccount defaultuser0
Fabian Gast WDAGUtilityAccount
De opdracht is voltooid.
No minidump file found
**** End of log ****
