Na Reboot :
Fix resultaat van Farbar Recovery Scan Tool (x64) Versie: 15-03-2017
Gestart door Probook (01-04-2017 11:53:31) Run:1
Gestart vanaf C:\Users\Probook\Desktop
Geladen Profielen: Probook (Beschikbare Profielen: Probook)
Boot Modus: Normal
fixlist inhoud:
start
CreateRestorePoint:
EmptyTemp:
CloseProcesses:
HKLM-x32\...\Run: [] => [X]
GroupPolicy: Restrictie <======= AANDACHT
2017-04-01 10:43 - 2017-04-01 10:43 - 00098816 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32api.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00110080 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\pywintypes27.dll
2017-04-01 10:43 - 2017-04-01 10:43 - 00364544 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\pythoncom27.dll
2017-04-01 10:43 - 2017-04-01 10:43 - 00320512 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32com.shell.shell.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00914432 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_hashlib.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 01176576 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._core_.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00806400 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._gdi_.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00816128 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._windows_.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 01067008 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._controls_.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00733184 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._misc_.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00682496 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\pysqlite2._sqlite.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00088064 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_ctypes.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00686080 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\unicodedata.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00119808 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32file.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00108544 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32security.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00007168 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\hashobjs_ext.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00017920 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\thumbnails_ext.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00088064 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\usb_ext.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00012800 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\common.time34.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00018432 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32event.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00167936 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32gui.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00046080 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_socket.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 01303552 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_ssl.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00128512 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_elementtree.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00127488 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\pyexpat.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00038912 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32inet.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00036864 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_psutil_windows.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00524248 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\windows._lib_cacheinvalidation.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00011264 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32crypt.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00123392 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._wizard.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00077312 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._html2.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00027648 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_multiprocessing.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00020480 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\_yappi.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00035840 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32process.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00078848 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._animate.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00024064 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32pipe.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00010240 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\select.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00025600 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32pdh.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00017408 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32profile.pyd
2017-04-01 10:43 - 2017-04-01 10:43 - 00022528 ____R () C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32ts.pyd
cmd: ipconfig /flushdns
cmd: netsh winsock reset
Herstelpunt is succesvol gemaakt.
Proces succesvol afgesloten.
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\ => waarde is succesvol verwijderd.
C:\Windows\system32\GroupPolicy\Machine => is succesvol verplaatst.
C:\Windows\system32\GroupPolicy\GPT.ini => is succesvol verplaatst.
C:\Windows\SysWOW64\GroupPolicy\GPT.ini => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32api.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\pywintypes27.dll => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\pythoncom27.dll => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32com.shell.shell.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_hashlib.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._core_.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._gdi_.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._windows_.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._controls_.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._misc_.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\pysqlite2._sqlite.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_ctypes.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\unicodedata.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32file.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32security.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\hashobjs_ext.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\thumbnails_ext.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\usb_ext.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\common.time34.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32event.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32gui.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_socket.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_ssl.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_elementtree.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\pyexpat.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32inet.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_psutil_windows.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\windows._lib_cacheinvalidation.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32crypt.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._wizard.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._html2.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_multiprocessing.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\_yappi.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32process.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\wx._animate.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32pipe.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\select.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32pdh.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32profile.pyd => is succesvol verplaatst.
C:\Users\Probook\AppData\Local\Temp\_MEI35802\win32ts.pyd => is succesvol verplaatst.
========= ipconfig /flushdns =========
Windows IP-configuratie
De DNS-omzettingscache is leeggemaakt.
========= Eind van CMD: =========
========= netsh winsock reset =========
De Winsock-catalogus is opnieuw ingesteld.
De computer dient opnieuw te worden opgestart om het opnieuw instellen te voltooien.
=========== EmptyTemp: ==========
BITS transfer queue => 8388608 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 6705952 B
Java, Flash, Steam htmlcache => 0 B
Windows/system/drivers => 120914 B
Edge => 0 B
Chrome => 620215223 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Users => 0 B
Default => 0 B
Public => 0 B
ProgramData => 0 B
systemprofile => 16802 B
systemprofile32 => 66356 B
LocalService => 0 B
NetworkService => 32502 B
Probook => 31419752 B
RecycleBin => 0 B
EmptyTemp: => 636.1 MB tijdelijke gegevens verwijderd.
Het systeem moest herstart worden.
==== Eind van Fixlog 11:53:52 ====
En de iconen zijn er weer
