Ik hoop dat dit u helpt.
Ran by Gurjot (administrator) on 06-08-2018 at 17:47:32
Running from "C:\Users\Gurjot\Desktop"
Model: HP Pavilion Sleekbook 15 PC Manufacturer: Hewlett-Packard
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Realtek PCIe FE Family Controller = Ethernet (Connected)
Qualcomm Atheros AR9485 802.11b|g|n WiFi Adapter = Wi-Fi (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled taskoffload=disabled
set interface interface="LAN-verbinding* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 12" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="other_0" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="ethernet_3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled rabaseddnsconfig=disabled dhcpstaticipcoexistence=disabled
set interface interface="wireless_6" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled rabaseddnsconfig=disabled dhcpstaticipcoexistence=disabled
set interface interface="wireless_7" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled rabaseddnsconfig=disabled dhcpstaticipcoexistence=disabled
set interface interface="LAN-verbinding* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="LAN-verbinding* 5" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Gurjot
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Qualcomm Atheros AR9485 802.11b|g|n WiFi Adapter
Physical Address. . . . . . . . . : 20-16-D8-13-8D-10
Wireless LAN adapter LAN-verbinding* 4:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
Physical Address. . . . . . . . . : 12-16-D8-13-8D-10
Wireless LAN adapter LAN-verbinding* 5:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5
Physical Address. . . . . . . . . : 22-16-D8-13-8D-10
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 84-34-97-89-49-24
Link-local IPv6 Address . . . . . : fe80::bd41:381e:ab:59b%18(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.2(Preferred)
Lease Obtained. . . . . . . . . . : zaterdag 4 augustus 2018 20:07:22
Lease Expires . . . . . . . . . . : dinsdag 7 augustus 2018 17:42:30
Default Gateway . . . . . . . . . : fe80::364d:eaff:fe88:23f9%18
192.168.2.254
DHCP Server . . . . . . . . . . . : 192.168.2.254
DHCPv6 IAID . . . . . . . . . . . : 310654103
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-1A-FE-BF-84-34-97-89-49-24
DNS Servers . . . . . . . . . . . : fe80::364d:eaff:fe88:23f9%18
192.168.2.254
Server: router.home
Address: fe80::364d:eaff:fe88:23f9
Pinging google.com [216.58.212.142] with 32 bytes of data:
Reply from 216.58.212.142: bytes=32 time=21ms TTL=57
Reply from 216.58.212.142: bytes=32 time=20ms TTL=57
Ping statistics for 216.58.212.142:
Minimum = 20ms, Maximum = 21ms, Average = 20ms
Server: mijnmodem.kpn.home
Pinging yahoo.com [98.137.246.7] with 32 bytes of data:
Reply from 98.137.246.7: bytes=32 time=176ms TTL=53
Reply from 98.137.246.7: bytes=32 time=175ms TTL=53
Ping statistics for 98.137.246.7:
Minimum = 175ms, Maximum = 176ms, Average = 175ms
Interface List
19...20 16 d8 13 8d 10 ......Qualcomm Atheros AR9485 802.11b|g|n WiFi Adapter
5...12 16 d8 13 8d 10 ......Microsoft Wi-Fi Direct Virtual Adapter #4
17...22 16 d8 13 8d 10 ......Microsoft Wi-Fi Direct Virtual Adapter #5
18...84 34 97 89 49 24 ......Realtek PCIe FE Family Controller
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.2.254 192.168.2.2 35
192.168.2.0 255.255.255.0 On-link 192.168.2.2 291
192.168.2.2 255.255.255.255 On-link 192.168.2.2 291
192.168.2.255 255.255.255.255 On-link 192.168.2.2 291
224.0.0.0 240.0.0.0 On-link 192.168.2.2 291
255.255.255.255 255.255.255.255 On-link 192.168.2.2 291
Persistent Routes:
None
IPv6 Route Table
Active Routes:
18 291 ::/0 fe80::364d:eaff:fe88:23f9
1 331 ::1/128 On-link
18 291 fe80::/64 On-link
18 291 fe80::bd41:381e:ab:59b/128
On-link
1 331 ff00::/8 On-link
18 291 ff00::/8 On-link
Persistent Routes:
None
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [64000] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
Application errors:
Error: (07/03/2018 02:49:04 PM) (Source: Perflib) (User: )
Description: aspnet_stateC:\Windows\System32\aspnet_counters.dll8
Error: (07/03/2018 02:49:03 PM) (Source: Perflib) (User: )
Description: ASP.NET_4.0.30319C:\Windows\System32\aspnet_counters.dll8
Description: ASP.NETC:\Windows\System32\aspnet_counters.dll8
Error: (07/03/2018 02:45:30 PM) (Source: SideBySide) (User: )
Description: Kan activeringscontext voor '51.0.2683.0,language="*",type="win32",version="51.0.2683.0"1' niet maken.
Kan afhankelijke assembly 51.0.2683.0,language="*",type="win32",version="51.0.2683.0" niet vinden.
Gebruik sxstrace.exe voor een gedetailleerde diagnose.
Error: (07/03/2018 07:29:26 AM) (Source: SideBySide) (User: )
Error: (07/02/2018 11:22:22 PM) (Source: Bonjour Service) (User: )
Description: Task Scheduling Error: m->NextScheduledSPRetry 15641
Description: Task Scheduling Error: m->NextScheduledEvent 15641
Description: Task Scheduling Error: Continuously busy for more than a second
Error: (07/02/2018 09:44:01 PM) (Source: Application Error) (User: )
Description: Naam van toepassing met fout: Explorer.EXE, versie: 10.0.17134.1, tijdstempel: 0x425b30b2
Naam van module met fout: ntdll.dll, versie: 10.0.17134.112, tijdstempel: 0x6529f37c
Uitzonderingscode: 0xc0000005
Foutmarge: 0x000000000002108f
Id van proces met fout: 0x24a0
Starttijd van toepassing met fout: 0xExplorer.EXE0
Pad naar toepassing met fout: Explorer.EXE1
Pad naar module met fout: Explorer.EXE2
Rapport-id: Explorer.EXE3
Volledige pakketnaam met fout: Explorer.EXE4
Relatieve toepassings-id van pakket met fout: Explorer.EXE5
Error: (07/02/2018 09:43:47 PM) (Source: SideBySide) (User: )
System errors:
Error: (07/13/2018 08:26:27 AM) (Source: DCOM) (User: NT AUTHORITY)
Description: 1068netprofmNiet beschikbaar{A47979D2-C419-11D9-A5B4-001185AD2B89}
Error: (07/13/2018 08:26:27 AM) (Source: Service Control Manager) (User: )
Description: De RasMan-service is afhankelijk van de SstpSvc-service, die vanwege de volgende fout niet kan worden gestart:
%%0 = De bewerking is voltooid.
Error: (07/13/2018 08:26:26 AM) (Source: DCOM) (User: NT AUTHORITY)
Microsoft Office Sessions:
Error: (07/03/2018 02:49:04 PM) (Source: Perflib)(User: )
Error: (07/03/2018 02:49:03 PM) (Source: Perflib)(User: )
Error: (07/03/2018 02:45:30 PM) (Source: SideBySide)(User: )
Description: 51.0.2683.0,language="*",type="win32",version="51.0.2683.0"C:\Users\Gurjot\AppData\Local\chromium\Application\chrome.exe
Error: (07/03/2018 07:29:26 AM) (Source: SideBySide)(User: )
Error: (07/02/2018 11:22:22 PM) (Source: Bonjour Service)(User: )
Error: (07/02/2018 09:44:01 PM) (Source: Application Error)(User: )
Description: Explorer.EXE10.0.17134.1425b30b2ntdll.dll10.0.17134.1126529f37cc0000005000000000002108f24a001d4123cdee5205dC:\WINDOWS\Explorer.EXEC:\WINDOWS\SYSTEM32\ntdll.dll63e2c03c-6f9b-45bf-b79f-13311a0b0d2b
Error: (07/02/2018 09:43:47 PM) (Source: SideBySide)(User: )
. . (HKLM\...\{12B07FF1-29CB-45AC-B493-1DB88BE717BD}) (Version: 7.1 - Intel) Hidden
. . . (HKLM-x32\...\{C01175B6-6575-4526-A55B-2BC2F10BA083}) (Version: 2.7.2.4 - Intel) Hidden
Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 22.0.0.153 - Adobe Systems Incorporated)
Adobe Digital Editions 4.5 (HKLM-x32\...\Adobe Digital Editions 4.5) (Version: 4.5.0 - Adobe Systems Incorporated)
Adobe Flash Player 30 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 30.0.0.134 - Adobe Systems Incorporated)
Adobe Reader XI (11.0.23) - Nederlands (HKLM-x32\...\{AC76BA86-7AD7-1043-7B44-AB0000000001}) (Version: 11.0.23 - Adobe Systems Incorporated)
Adobe Shockwave Player 11.6 (HKLM-x32\...\Adobe Shockwave Player) (Version: 11.6.5.635 - Adobe Systems, Inc.)
Apple Application Support (32-bit) (HKLM-x32\...\{543F829B-4591-4B2F-AF63-6E6E6AE59EB2}) (Version: 6.4 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{0ECA3BB5-4410-414B-B226-241FF1C12CD0}) (Version: 6.4 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{A05FDFEC-4377-49E0-82CB-B6D1386E89DA}) (Version: 11.3.0.9 - Apple Inc.)
CyberLink YouCam (HKLM-x32\...\InstallShield_{01FB4998-33C4-4431-85ED-079E3EEFE75D}) (Version: 3.5.4.5527 - CyberLink Corp.)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
Energy Star (HKLM\...\{0FA995CC-C849-4755-B14B-5404CC75DC24}) (Version: 1.0.8 - Hewlett-Packard)
EPSON XP-312 313 315 Series Printer Uninstall (HKLM\...\EPSON XP-312 313 315 Series) (Version: - SEIKO EPSON Corporation)
EPSON-handleidingen (HKLM-x32\...\{84CECC1B-21EF-41B1-9A91-3E724E5D99D3}) (Version: 1.40.0.0 - SEIKO EPSON CORPORATION)
Fiesta Online NA version 1.0 (HKLM-x32\...\Fiesta Online NA_is1) (Version: 1.0 - gamigo AG)
Google Chrome (HKLM-x32\...\{A58EE139-F99A-3991-B9D2-EBB6A6E2F9AE}) (Version: 67.0.3396.99 - Google, Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.17 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.22.5 - Google Inc.) Hidden
Hewlett-Packard ACLM.NET v1.2.2.3 (HKLM-x32\...\{6F340107-F9AA-47C6-B54C-C3A19F11553F}) (Version: 1.00.0000 - Hewlett-Packard Company) Hidden
HP 3D DriveGuard (HKLM\...\{8A9B16F0-A84E-4EC5-BDA7-0ACCE79FB043}) (Version: 4.2.9.1 - Hewlett-Packard Company)
HP Connected Music (Meridian - installer) (HKLM-x32\...\StartHPConnectedMusic) (Version: v1.0 - Meridian Audio Ltd)
HP CoolSense (HKLM-x32\...\{16B7BDA1-B967-4D2D-8B27-E12727C28350}) (Version: 2.10.3 - Hewlett-Packard Company)
HP Documentation (HKLM-x32\...\{D044EBE7-94E7-4C49-90FC-9069E3F374E1}) (Version: 1.1.0.0 - Hewlett-Packard)
HP Quick Launch (HKLM-x32\...\{E5823036-6F09-4D0A-B05C-E2BAA129288A}) (Version: 3.0.6 - Hewlett-Packard Company)
HP Registration Service (HKLM\...\{E4D6CCF2-0AAF-4B9C-9DE5-893EDC9B4BAA}) (Version: 1.0.5976.4186 - Hewlett-Packard)
HP Software Framework (HKLM-x32\...\{4983EBE7-5117-43C9-8DE1-FFEBFDBD35DB}) (Version: 4.6.8.1 - Hewlett-Packard Company)
HP Utility Center (HKLM-x32\...\{0C57987A-A03A-4B95-A309-D23F78F406CA}) (Version: 1.0.7 - Hewlett-Packard)
HP Wireless Button Driver (HKLM-x32\...\{EFA01423-3857-468C-B7B6-F30AA08E50BC}) (Version: 1.1.5.1 - Hewlett-Packard Company)
IDT Audio (HKLM-x32\...\{E3A5A8AB-58F6-45FF-AFCB-C9AE18C05001}) (Version: 1.0.6425.0 - IDT)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 8.1.30.1349 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.10.4425 - Intel Corporation)
Intel(R) SDK for OpenCL - CPU Only Runtime Package (HKLM-x32\...\{FCB3772C-B7D0-4933-B1A9-3707EBACC573}) (Version: 2.0.0.37149 - Intel Corporation)
Intel® Driver Update Utility (HKLM-x32\...\{954190cd-c66c-4650-bd15-f3dd85f2ae15}) (Version: 2.7.2.4 - Intel)
Java 8 Update 101 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F64180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
Java 8 Update 101 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
KB4023057 (HKLM\...\{ED06689A-33B7-4D35-8F76-36A82CD03406}) (Version: 2.3.0.0 - Microsoft Corporation)
League of Legends (HKLM-x32\...\{2F5D7825-7460-43B1-B467-7F9737557108}) (Version: 4.2.1 - Riot Games) Hidden
League of Legends (HKLM-x32\...\League of Legends 1.0) (Version: 1.0 - Riot Games, Inc)
League of Legends (HKLM-x32\...\League of Legends 4.2.1) (Version: 4.2.1 - Riot Games)
Microsoft Office (HKLM-x32\...\{95140000-0070-0000-0000-0000000FF1CE}) (Version: 14.0.6120.5004 - Microsoft Corporation)
Microsoft Office Professional Plus 2010 (HKLM\...\Office14.PROPLUS) (Version: 14.0.7015.1000 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (HKLM-x32\...\{837b34e3-7c30-493c-8f6a-2b0f04e2912c}) (Version: 8.0.59193 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}) (Version: 8.0.59192 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729 (HKLM-x32\...\{402ED4A1-8F5B-387A-8688-997ABF58B8F2}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 (HKLM-x32\...\{1F1C2DFC-2D24-3E06-BCB8-725134ADF989}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Opera Stable 54.0.2952.64 (HKLM-x32\...\Opera 54.0.2952.64) (Version: 54.0.2952.64 - Opera Software)
Qualcomm Atheros Driver Installation Program (HKLM-x32\...\{C3A32068-8AB1-4327-BB16-BED9C6219DC7}) (Version: 10.0 - Qualcomm Atheros)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 8.3.730.2012 - Realtek)
Realtek PCIE Card Reader (HKLM-x32\...\{C1594429-8296-4652-BF54-9DBE4932A44C}) (Version: 6.2.8400.29029 - Realtek Semiconductor Corp.)
RuneScape Launcher 2.2.4 (HKLM\...\RuneScape Launcher_is1) (Version: 2.2.4 - Jagex Ltd)
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0011-0000-1000-0000000FF1CE}_Office14.PROPLUS_{A3364707-2F53-4C83-8F68-C9877A9080C7}) (Version: - Microsoft)
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0015-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0016-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0018-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0019-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001A-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001B-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001F-0407-1000-0000000FF1CE}_Office14.PROPLUS_{EE3A99C9-FD8F-4923-9F82-27365DA4B873}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001F-0409-1000-0000000FF1CE}_Office14.PROPLUS_{C814F7D9-CE9D-45AA-BA7C-88BDD0E1EB7C}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001F-040C-1000-0000000FF1CE}_Office14.PROPLUS_{77A8B979-11B0-4774-8003-574EE8A4BC22}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-001F-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C281A20E-A7DE-4950-8656-13E31F2DF194}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-002C-0413-1000-0000000FF1CE}_Office14.PROPLUS_{8601DE11-B4B1-47B6-BA5F-C98AF303A1DD}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0043-0000-1000-0000000FF1CE}_Office14.PROPLUS_{F3FAAB68-7697-4B1F-A23A-72312565AEAB}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0043-0413-1000-0000000FF1CE}_Office14.PROPLUS_{040AFD12-179F-4557-8412-017A830C60A3}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-0044-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-006E-0413-1000-0000000FF1CE}_Office14.PROPLUS_{B063C2D2-FD29-44E9-A6EF-19BA4B62381B}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-00A1-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
Service Pack 2 for Microsoft Office 2010 (KB2687455) 64-Bit Edition (HKLM\...\{90140000-00BA-0413-1000-0000000FF1CE}_Office14.PROPLUS_{C17E141C-267D-4A15-A903-1AD09D8B0D62}) (Version: - Microsoft) Hidden
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
Synaptics Pointing Device Driver (HKLM\...\SynTPDeinstKey) (Version: 19.0.12.98 - Synaptics Incorporated)
Taalpakket voor Microsoft Visual Studio 2010 Tools for Office Runtime (x64) - NLD (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64) Language Pack - NLD) (Version: 10.0.50903 - Microsoft Corporation)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 15.4.3555.0308 - Microsoft Corporation)
Percentage of memory in use: 35%
Total physical RAM: 3988.28 MB
Available physical RAM: 2591.27 MB
Total Virtual: 4990.65 MB
Available Virtual: 3484.86 MB
1 Drive c: () (Fixed) (Total:447.6 GB) (Free:338.26 GB) NTFS
2 Drive d: (RECOVERY) (Fixed) (Total:16.04 GB) (Free:2.02 GB) NTFS
Gebruikersaccounts voor \\GURJOT
Gurjot WDAGUtilityAccount
De opdracht is voltooid.
No minidump file found
**** End of log ****
