Ik heb zojuist uw voorstel uitgevoerd.
Hier is de inhoud van de logfile:
Ran by Gebruiker (administrator) on 08-12-2017 at 16:03:15
Running from "C:\Users\Gebruiker\Desktop"
Microsoft Windows 10 Pro (X64)
Model: HP EliteBook 2540p Manufacturer: Hewlett-Packard
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Intel(R) 82577LM Gigabit Network Connection = Ethernet 2 (Connected)
Intel(R) Centrino(R) Advanced-N 6200 AGN stuurprogramma = Wi-Fi (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global defaultcurhoplimit=64
set interface interface="LAN-verbinding* 9" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth-netwerkverbinding" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Henk
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Intel(R) 82577LM Gigabit Network Connection
Physical Address. . . . . . . . . : B4-99-BA-EE-37-F1
IPv6 Address. . . . . . . . . . . : 2a02:a44f:26a9:1:a9ae:2b0e:f963:5d4a(Preferred)
Temporary IPv6 Address. . . . . . : 2a02:a44f:26a9:1:85f1:3946:3039:cebd(Preferred)
Link-local IPv6 Address . . . . . : fe80::a9ae:2b0e:f963:5d4a%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.4(Preferred)
Lease Obtained. . . . . . . . . . : donderdag 7 december 2017 20:03:48
Lease Expires . . . . . . . . . . : zaterdag 9 december 2017 15:52:51
Default Gateway . . . . . . . . . : fe80::3ad8:2fff:fe12:5f56%10
192.168.2.254
DHCP Server . . . . . . . . . . . : 192.168.2.254
DHCPv6 IAID . . . . . . . . . . . : 146053562
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-95-3C-95-B4-99-BA-EE-37-F1
DNS Servers . . . . . . . . . . . : fe80::3ad8:2fff:fe12:5f56%10
192.168.2.254
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN
Physical Address. . . . . . . . . : 18-3D-A2-7D-3E-18
Wireless LAN adapter LAN-verbinding* 9:
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : 18-3D-A2-7D-3E-19
Tunnel adapter LAN-verbinding* 12:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:858:2bca:a9a8:9842(Preferred)
Link-local IPv6 Address . . . . . : fe80::858:2bca:a9a8:9842%17(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 268435456
NetBIOS over Tcpip. . . . . . . . : Disabled
Server: router.home
Address: fe80::3ad8:2fff:fe12:5f56
Addresses: 2a00:1450:400e:80a::200e
172.217.17.46
Pinging google.com [2a00:1450:400e:80a::200e] with 32 bytes of data:
Reply from 2a00:1450:400e:80a::200e: time=4ms
Ping statistics for 2a00:1450:400e:80a::200e:
Minimum = 4ms, Maximum = 4ms, Average = 4ms
Server: mijnmodem.kpn.home
Addresses: 2001:4998:44:204::100d
2001:4998:c:e33::53
2001:4998:58:2201::73
206.190.39.42
98.139.180.180
98.138.252.38
Pinging yahoo.com [2001:4998:44:204::100d] with 32 bytes of data:
Reply from 2001:4998:44:204::100d: time=121ms
Ping statistics for 2001:4998:44:204::100d:
Minimum = 121ms, Maximum = 121ms, Average = 121ms
Reply from 127.0.0.1: bytes=32 time<1ms TTL=64
Interface List
10...b4 99 ba ee 37 f1 ......Intel(R) 82577LM Gigabit Network Connection
9...18 3d a2 7d 3e 18 ......Intel(R) Centrino(R) Advanced-N 6200 AGN
4...18 3d a2 7d 3e 19 ......Microsoft Hosted Network Virtual Adapter
17...00 00 00 00 00 00 00 e0 Microsoft Teredo Tunneling Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.2.254 192.168.2.4 25
169.254.0.0 255.255.0.0 On-link 192.168.2.4 30
169.254.255.255 255.255.255.255 On-link 192.168.2.4 281
192.168.2.0 255.255.255.0 On-link 192.168.2.4 281
192.168.2.4 255.255.255.255 On-link 192.168.2.4 281
192.168.2.255 255.255.255.255 On-link 192.168.2.4 281
224.0.0.0 240.0.0.0 On-link 192.168.2.4 281
255.255.255.255 255.255.255.255 On-link 192.168.2.4 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
10 281 ::/0 fe80::3ad8:2fff:fe12:5f56
1 331 ::1/128 On-link
17 331 2001::/32 On-link
17 331 2001:0:9d38:90d7:858:2bca:a9a8:9842/128
On-link
10 281 2a02:a44f:26a9:1::/64 On-link
10 281 2a02:a44f:26a9:1:85f1:3946:3039:cebd/128
On-link
10 281 2a02:a44f:26a9:1:a9ae:2b0e:f963:5d4a/128
On-link
10 281 fe80::/64 On-link
17 331 fe80::/64 On-link
17 331 fe80::858:2bca:a9a8:9842/128
On-link
10 281 fe80::a9ae:2b0e:f963:5d4a/128
On-link
1 331 ff00::/8 On-link
10 281 ff00::/8 On-link
17 331 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWOW64\NLAapi.dll [63488] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70144] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23040] (Microsoft Corporation)
Catalog5 07 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [94208] (Apple Computer, Inc.)
Catalog5 08 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [305568] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [66560] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [79872] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [358600] (Microsoft Corporation)
Application errors:
Error: (12/08/2017 04:03:27 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:27.216]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:25 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:25.703]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:24 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:24.191]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:22 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:22.678]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:21 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:21.170]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:19 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:19.665]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:18 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:18.161]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:16 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:16.648]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:15 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:15.131]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:13 PM) (Source: Brother BrLog) (User: )
Description: WDLMW BrtWDLMW: [2017/12/08 16:03:13.619]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
System errors:
Error: (12/08/2017 03:53:38 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: toepassingsspecifiekLokaalActiveren{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (12/07/2017 09:00:10 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: standaard voor deze computerLokaalActiveren{C2F03A33-21F5-47FA-B4BB-156362A2F239}{316CDED5-E4AE-4B15-9113-7055D84DCC97}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (via LRPC)Niet beschikbaarNiet beschikbaar
Error: (12/07/2017 09:00:09 PM) (Source: BTHUSB) (User: )
Description: Er is een onbekende fout in de lokale Bluetooth-adapter opgetreden en deze wordt niet gebruikt. Het stuurprogramma wordt verwijderd.
Error: (12/07/2017 08:30:43 PM) (Source: Microsoft-Windows-WindowsUpdateClient) (User: NT AUTHORITY)
Description: Installatiefout: de volgende update kan niet worden geïnstalleerd, foutcode 0x80070643: Definitie-update voor Windows Defender Antivirus - KB2267602 (definitie 1.259.37.0).
Microsoft Office Sessions:
Error: (12/08/2017 04:03:28 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:28.728]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:27 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:27.216]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:25 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:25.703]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:24 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:24.191]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:22 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:22.678]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:21 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:21.170]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:19 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:19.665]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:18 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:18.161]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:16 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:16.648]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
Error: (12/08/2017 04:03:15 PM) (Source: Brother BrLog)(User: )
Description: WDLMWBrtWDLMW: [2017/12/08 16:03:15.131]: [00006324]: lperrcode->api = 1 , lperrcode->code = 2
CodeIntegrity Errors:
Date: 2017-12-07 20:28:29.057
Description: Windows is unable to verify the image integrity of the file \Device\HarddiskVolume2\ProgramData\Microsoft\Windows Defender\Platform\4.12.17007.17123-0\Drivers\WdBoot.sys because file hash could not be found on the system. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
Date: 2017-12-07 20:28:29.053
Date: 2017-12-04 21:52:02.127
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe) attempted to load \Device\HarddiskVolume2\Windows\assembly\GAC\Microsoft.StdFormat\7.0.3300.0__b03f5f7f11d50a3a\Microsoft.StdFormat.dll that did not meet the Microsoft signing level requirements.
Date: 2017-12-04 21:52:02.057
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe) attempted to load \Device\HarddiskVolume2\Windows\assembly\GAC\ADODB\7.0.3300.0__b03f5f7f11d50a3a\ADODB.dll that did not meet the Microsoft signing level requirements.
Date: 2017-12-04 21:52:01.972
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe) attempted to load \Device\HarddiskVolume2\Windows\assembly\GAC\MSDATASRC\7.0.3300.0__b03f5f7f11d50a3a\MSDATASRC.dll that did not meet the Microsoft signing level requirements.
Date: 2017-12-04 21:52:01.839
Date: 2017-12-04 21:52:01.805
Date: 2017-12-04 21:52:01.774
Date: 2017-12-04 21:51:56.415
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorsvw.exe) attempted to load \Device\HarddiskVolume2\Windows\assembly\GAC\stdole\7.0.3300.0__b03f5f7f11d50a3a\stdole.dll that did not meet the Microsoft signing level requirements.
Date: 2017-12-04 21:51:55.603
Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 27.0.0.124 - Adobe Systems Incorporated)
Adobe Creative Suite 3 Design Premium toevoegen of verwijderen (HKLM-x32\...\Adobe_4f447996d55a2562c006714721fae31) (Version: 1.0 - Adobe Systems Incorporated)
Adobe Flash Player 27 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 27.0.0.187 - Adobe Systems Incorporated)
Adobe Flash Player 27 PPAPI (HKLM-x32\...\Adobe Flash Player PPAPI) (Version: 27.0.0.187 - Adobe Systems Incorporated)
Adobe Shockwave Player 12.2 (HKLM-x32\...\Adobe Shockwave Player) (Version: 12.2.3.183 - Adobe Systems, Inc.)
Adobe Shockwave Player 12.3 (HKLM-x32\...\{175D1C2E-CEF4-4909-901D-52AF3CD8ECD2}) (Version: 12.3.1.201 - Adobe Systems, Inc)
Advanced SystemCare 11 (HKLM-x32\...\Advanced SystemCare_is1) (Version: 11.0.3 - IObit)
AHV content for Acrobat and Flash (HKLM-x32\...\{6BBAA81D-6A7E-43AD-8889-2F002DCAAFDD}) (Version: 1 - Adobe Systems Incorporated) Hidden
Brother MFL-Pro Suite MFC-5895CW (HKLM-x32\...\{184BF682-537C-4CAE-8789-6696508A4032}) (Version: 2.0.1.0 - Brother Industries, Ltd.)
CCleaner (HKLM\...\CCleaner) (Version: 5.37 - Piriform)
CEWE Fotoservice (HKLM-x32\...\CEWE Fotoservice) (Version: 6.2.6 - CEWE Stiftung u Co. KGaA)
CutePDF Writer 3.1 (HKLM\...\CutePDF Writer Installation) (Version: 3.1 - Acro Software Inc.)
Cybereason RansomFree 2.4.1.0 (HKLM-x32\...\{88BF86F8-A656-4397-B4CE-9C5956E82B1A}) (Version: 2.4.1.0 - Cybereason Inc.)
Driver Booster 5 (HKLM-x32\...\Driver Booster_is1) (Version: 5.1.0 - IObit)
FastStone Image Viewer 6.4 (HKLM-x32\...\FastStone Image Viewer) (Version: 6.4 - FastStone Soft)
FreeOCR v5.4 (HKLM-x32\...\freeocr_is1) (Version: - )
Gadwin PrintScreen (64-Bit) (HKLM\...\{819A52E1-0929-469A-BEB6-1AEBE0873CFC}) (Version: 5.4.2.0 - Gadwin Systems)
GIMP 2.8.22 (HKLM\...\GIMP-2_is1) (Version: 2.8.22 - The GIMP Team)
Google Chrome (HKLM-x32\...\{DD5242DA-8169-38CC-B224-F1A85F351A0B}) (Version: 62.0.3202.94 - Google, Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
IDT Audio (HKLM-x32\...\{E3A5A8AB-58F6-45FF-AFCB-C9AE18C05001}) (Version: 1.0.6275.0 - IDT)
InfraRecorder 0.53 (x64 edition) (HKLM\...\{2C22EA92-CB30-4932-0053-000001000000}) (Version: 0.53.00.00 - Christian Kindahl)
Intel(R) Network Connections Drivers (HKLM\...\PROSet) (Version: 19.0 - Intel)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 8.15.10.2993 - Intel Corporation)
Java 8 Update 151 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F64180151F0}) (Version: 8.0.1510.12 - Oracle Corporation)
Java 8 Update 151 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180151F0}) (Version: 8.0.1510.12 - Oracle Corporation)
KPN Back-up Online (HKLM\...\KPN Back-up Online) (Version: 16.8.0.17235 - KPN)
LibreOffice 5.4.3.2 (HKLM\...\{5FFD3D4F-8AA0-4C6F-8B3C-AB0D8CD297C9}) (Version: 5.4.3.2 - The Document Foundation)
LSI HDA Modem (HKLM\...\LSI Soft Modem) (Version: 2.2.100 - LSI Corporation)
Microsoft Office 2016 voor Thuisgebruik en Studenten - nl-nl (HKLM\...\HomeStudentRetail - nl-nl) (Version: 16.0.8625.2139 - Microsoft Corporation)
Microsoft Office File Validation Add-In (HKLM-x32\...\{90140000-2005-0000-0000-0000000FF1CE}) (Version: 14.0.5130.5003 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.3.7131.1115 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{071c9b48-7c32-4621-a0ac-3f809523288f}) (Version: 8.0.56336 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 (HKLM-x32\...\{e2803110-78b3-4664-a479-3611a381656a}) (Version: 14.0.24215.1 - Microsoft Corporation)
Mozilla Firefox 57.0 (x64 nl) (HKLM\...\Mozilla Firefox 57.0 (x64 nl)) (Version: 57.0 - Mozilla)
Mozilla Maintenance Service (HKLM-x32\...\MozillaMaintenanceService) (Version: 57.0.0.6525 - Mozilla)
Mozilla Thunderbird 52.5.0 (x86 nl) (HKLM-x32\...\Mozilla Thunderbird 52.5.0 (x86 nl)) (Version: 52.5.0 - Mozilla)
MusicBrainz Picard (HKLM-x32\...\MusicBrainz Picard) (Version: 1.4.2 - MusicBrainz)
Office 16 Click-to-Run Extensibility Component (HKLM-x32\...\{90160000-008C-0000-0000-0000000FF1CE}) (Version: 16.0.8625.2139 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Extensibility Component 64-bit Registration (HKLM\...\{90160000-00DD-0000-1000-0000000FF1CE}) (Version: 16.0.8625.2139 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-008F-0000-1000-0000000FF1CE}) (Version: 16.0.8625.2139 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM-x32\...\{90160000-008C-0413-0000-0000000FF1CE}) (Version: 16.0.8326.2076 - Microsoft Corporation) Hidden
Opera Stable 49.0.2725.47 (HKLM-x32\...\Opera 49.0.2725.47) (Version: 49.0.2725.47 - Opera Software)
PaperPort Image Printer 64-bit (HKLM\...\{ABA4FAF1-6389-45F9-92CE-3914A4E5C471}) (Version: 1.00.0000 - Nuance Communications, Inc.)
PDF Settings (HKLM-x32\...\{AC5B0C19-D851-42F4-BDA0-410ECF7F70A5}) (Version: 1.0 - Adobe Systems Incorporated) Hidden
Pixillion Image Converter (HKLM-x32\...\Pixillion) (Version: 4.09 - NCH Software)
Revo Uninstaller 2.0.4 (HKLM\...\{A28DBDA2-3CC7-4ADC-8BFE-66D7743C6C97}_is1) (Version: 2.0.4 - VS Revo Group, Ltd.)
ScanSoft PaperPort 11 (HKLM-x32\...\{02570AE0-BEE0-4A6C-BE3F-D806E9F2EA17}) (Version: 11.2.0000 - ScanSoft, Inc.)
Skype™ 7.40 (HKLM-x32\...\{3B7E914A-93D5-4A29-92BB-AF8C3F66C431}) (Version: 7.40.151 - Skype Technologies S.A.)
SonixImageScanTool (HKLM-x32\...\{43F2266B-DBE3-4BC4-960F-80A3E040C5A5}) (Version: 1.1 - Sonix)
SumatraPDF (HKLM\...\SumatraPDF) (Version: 3.1.2 - Krzysztof Kowalczyk)
SumatraPDF (HKLM-x32\...\SumatraPDF) (Version: 1.7 - Krzysztof Kowalczyk)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
Synaptics Pointing Device Driver (HKLM\...\SynTPDeinstKey) (Version: 15.0.24.0 - Synaptics Incorporated)
TomTom MyDrive Connect 4.1.5.3181 (HKLM-x32\...\MyDriveConnect) (Version: 4.1.5.3181 - TomTom)
VideoPad Video Editor (HKLM-x32\...\VideoPad) (Version: 5.03 - NCH Software)
Visual Studio C++ 10.0 Runtime (HKLM-x32\...\{4412F224-3849-4461-A3E9-DEEF8D252790}) (Version: 10.0.0 - TomTom International B.V.)
VLC media player (HKLM\...\VLC media player) (Version: 2.2.6 - VideoLAN)
Windows 10 Update and Privacy Settings (HKLM\...\{293F2009-0145-450B-B4AA-063D43FB368C}) (Version: 1.0.13.0 - Microsoft Corporation)
WinRAR 5.50 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.50.0 - win.rar GmbH)
Percentage of memory in use: 42%
Total physical RAM: 5935.38 MB
Available physical RAM: 3423.34 MB
Total Virtual: 12079.38 MB
Available Virtual: 9187.81 MB
1 Drive c: () (Fixed) (Total:232.35 GB) (Free:132.43 GB) NTFS
Gebruikersaccounts voor \\HENK
Gebruiker
De opdracht is voltooid.
No minidump file found
**** End of log ****
